Old 08-11-2011, 07:05 PM
esarvey's Avatar
esarvey esarvey is offline
Default 1641?
I am buying a cub that has isues, it was just rebuilt not to long ago, po states that, when pto is engaged the engine quits. claims that they couldn't git govener right ! scary that a rebuilder cain't set governer??? anybody got ideas???
Thanks Daduke of
DaDuke of
2145,1864,1811,1810,1541,1330,1210,1020,1641,147,1 24,73, IH FARMALL CUB. 7254, 1863, IH 982
Old 08-11-2011, 09:01 PM
Vince_o Vince_o is offline
Id tell you but then Id have to kill you.
Wonder how it quits? Like just shuts off or starves out? Ive been known to mess up one or two.
Im not perfect like others are.
Ill be in the truck all day tomorrow, have to go about 3 hours east of Monroe. Going to swing past David Greens place with an empty wagon and steel his tractors. Ill leave the green one!
Im so bad!
Old 08-11-2011, 10:21 PM
Im so bad!
Bring that green one to me not the David Green one tho!
Old 08-11-2011, 10:36 PM
Earl, thats got a Briggs Vanguard in it. Could it be an electrical issue?
Old 08-11-2011, 10:52 PM
Iluvtruks0's Avatar
Im so bad!
I might be there, I might not, but I know my friends Mr Smith and Mr Wesson will be there. Speaking of empty wagon, Ive got one for you!! Had a guy come buy today and wanted it.
And that Green one is the best one here. So I wont be too upset. Besides, I know how to find you.
David in NC
Old 08-12-2011, 10:44 AM
esarvey's Avatar
Cool My people
Yo, vinny, U talkin to me, HUH? I have people to handle such threats,( guedio an the boys, do knee caps!!) Capish? guy said it drags engine down, when the pto is engade. safe trip, if ya need I have mr. Winchester,Rossi&Rugar to help U load at Davids place!!LOL
Im so bad!
DaDuke of
Old 08-14-2011, 02:09 PM
esarvey's Avatar
Default 1641 is home rescue work to begin
well on the trailer at house, short inspection, had a horse spring on gov. throt couldn't over come, made a good spring thats ok now, the air filter was full of oil,not good??? got it to turn over it almost poped but batt. box is low,crging now! have to go to John & Ritas per the boss will up date later.
DaDuke of
Old 08-14-2011, 02:15 PM
Earl that looks great! Better listen to the boss she looks mean as
Old 08-14-2011, 04:47 PM
Nice 1641, Earl!
Old 08-15-2011, 07:08 PM
esarvey's Avatar
Thumbs up the rescue
Dug deeper found, was firing back through the carb, checked the plugs, first one I pulled was a champion rcy17 gapped at 45 thous. soaking wet, pulled and put a Autolite 3924, gaped to 32 thous. the second plug was champ. dry gapped to 35 thous. left it in till I can git another good Autolite. Intermittantly it has no volts to any thing. pulled the ground wire off the Ign. sw. so mag can work, hot wired starter to run,sprayed gas from a windex bottle,direct to carb, pulled, choked to 3/4 full, throttle to a little more than idle. hot wired starter to run, Engine fired right off no knocks/smoke!!! got a good one Ing. sw replace, check grounds/wiring, will be another winner!!!
Love working on Class equipment, MTD stuff is a little touchy but can be saved!!!!
DaDuke of
