Old 08-14-2011, 12:05 PM
ronalddipietro ronalddipietro is offline
Default Mule Drive Belt will not stay on
OK.guys..I know it is not just this simple...but..If you have some expericnces on the Mule Drive belt twisting and rolling off a 107 Hydro Cub..Thing s I have done are:..Be certain that the belt is on correct..I also use only the IH Cub belt....How likely is the problem to be in the mule drive pully assembly?? or would it be miss-alligm,emt Of the hanger carriage..Links..etc...This is a sweet cub cadet..turns over twice before starting...no oil use..just this belt problem...If you want to see it...email me..(deepsouthsuppy@gmail.com)..
Ronald
Old 08-14-2011, 01:28 PM
young enthusiest's Avatar
Make sure that the tension pullies do not have bad bearings, make sure the pullies aren't worn out, make sure the tension is right, and that both pullies are even with each other. If one is too far back or too far forward, the belt will jump off. Is it jumping off at the PTO or at the mower? Or at the tension pullies? If you can tell us that we might be able to help you. Good luck!
