Old 08-24-2011, 11:58 AM
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Default 1810 Hydro leak I need your help
I am new to the older type Hydro, I have a leak where the speed control shaft come though the outer side of the hydro pump, I guess I am saying that right, I have pictures for you to look at, how and what is the easy way to fix this. I am use to all gear drives, any help would be great. thanks
Donny
Old 08-24-2011, 12:28 PM
CC1650Dave's Avatar
There's a seal in there, and you have to disassemble the whole hydro to get that shaft out to get to it. It's not a small job.
If you're going to replace it, you'll want to replace your gasket between the hydro and the diff, as well as the o-ring on the front of the hydro while you're at it.
The service manual will guide you through the job.
Old 08-24-2011, 06:33 PM
The right side trunnion seal does not require disassembly of the hydro unit; simply remove the snap ring and washer, pry out the seal, install a new one, and put the washer and snap ring back on.
Old 08-24-2011, 06:48 PM
I will add to the correct reply from Matt, it is also wise to clean the shaft a bit with fine emery paper removing any rust that might be there.
Using a ice pick to start a hole into which a sheet metal screw in inserted, makes a nice prying head to remove the seal with.
It is a relatively easy job unlike the other side which does require hydro disassembly.
Take care to not nick/damage the bore that the seal lives in.
Old 08-24-2011, 07:31 PM
Thanks Guys, I will try and get this done. where would find the number for the seal, thanks
Donny
Old 08-24-2011, 10:02 PM
Default seal on 1810
Does anyone know the number for the right side trunnion seal for the 1810 pump or where I could find it, thanks
Donny
Old 08-24-2011, 10:05 PM
From cubcadet.com parts list for the 1810: Seal# SU-9008000-6701 $11.69
Old 08-24-2011, 10:08 PM
Thanks, Dwayne
Donny
Old 08-24-2011, 10:24 PM
No problem
Old 08-24-2011, 11:51 PM
CC1650Dave's Avatar
So Matt, you can remove the seal with the shaft in place? The reason I answered as I did is because I was looking into replacing those seals on my 1650 project, and assumed I'd have to get the shafts out to get to the seals...
