Old 09-01-2011, 03:27 PM
maddog784's Avatar
Default 1864 Oil in Breather
We have an 1864 and we are having problems with oil making it to the inside of the intake air filter, right next to the carb intake. The oil is coming from the hose from the crankcase - can visibly see this. Installed a new reed valve thinking it would work and have no results. Compression is good. Any suggestions/solutions? New filter and valves were installed in the breather assembly.
Thanks,
Nate
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 09-01-2011, 08:57 PM
If the engine has some hours on it, it will push a little bit of oil into the air cleaner.
Now if it is flooding it with oil, usually a rebuild is in order.
In about 6 hours hard mowing use, my M-18 is down about 1/4 on the dipstick and some is in the air cleaner.
I don't find it a problem
