Old 09-05-2011, 05:59 PM
LarryW's Avatar
LarryW LarryW is offline
Default New Rototiller!
I found a rotary tiller and gear drive for $150. It was a reply to a wanted ad on CL. He threw some paint bomb on it though. Over spray was in the little utility wagon we got it out of so he must of did it after I called. Now I need to fix up that mess on top of the original mess. I also need to find some info on it like what type and size belts and such. I found the manual on the site for it. Time to study up on it. tiller 1And see if I can get some extenders. He painted over the ID tag but looks like its a 1. Any tips on cleaning the tag off? Will wire brush ruin the original lettering on the tag? Or would some chemical be better to take the paint off? Here are the pictures.
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 09-05-2011, 06:04 PM
Try mineral spirits or naptha...if he used really crappy paint, those will take it off. Otherwise, you're pretty much screwed. Any scraping, sanding, etc will also remove the lettering on the tag.
Old 09-05-2011, 06:24 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
Nice find since it sounds like the paint is fresh, so hopefully it will come off easier like Matt said.
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 09-05-2011, 06:39 PM
Congrats! You'll love how great of a job it will do.
Here's some info for you from our technical section of the site..
Belt chart
http://www.onlycubcadets.net/forum/showthread.php?t=25
Wild Bill's awesome tiller guide!
http://www.onlycubcadets.net/forum/s...ad.php?t=12320
Old 09-05-2011, 08:00 PM
LarryW's Avatar
Thanks everybody!
I drilled the rivets out. Put it in a dish. I didnt have any mineral spirits or naptha on hand but did have some acetone. So I put a little in the dish and let the tag soak for 5 minutes or so. Then most of it cleaned off with by wiping with an acetoned soaked paper towel. I let is soak another 5 minutes. Wiped some more with a towel and got it all off. None of the original writing appears damaged at all. Now I will just keep it in a safe place until I clean up the rest of the tiller and rivet it back on.
Model 1 Serial 3019
Cub Cadet 1811
Old 09-05-2011, 08:06 PM
Mountain Heritage's Avatar
Looks like a nice tiller, glade to hear and see the tag cleaned up nice. Definately a Series 1 due to the size ans number of tines. An extension in each end and a good cleaing and perhaps repaint properly will look good as new. Even better if you paint it the correct shade of off white. More I look at things i buy and peope just paint it white...gee whizz!!
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 09-05-2011, 08:45 PM
neo71665 neo71665 is offline
I'd rather see the wrong color paint than a rusted out mess on something I want. Paint is easier to fix than rust holes.
Old 09-05-2011, 10:11 PM
hydrocub hydrocub is offline
Amen to that .....I don't care about runs, color match , what ever .....
It beats the heck out of rust ...... I can always take paint off
Old 09-05-2011, 10:35 PM
Great score on the tiller, Larry!
Old 09-08-2011, 09:15 PM
Hornets Hornets is offline
Default Roto tiller
I was given recently a 129 cub cadet It needs complete restore. It come with a 1A U1111 6 tine roto tiller. I found a 3 gblade 42 " mower deck good shape off of a 105 cub cadet. my mule drive has some of the arms cut off. will the mower deck and roto yiller fit this machine. Hornets
