Old 09-06-2011, 07:38 PM
jpianalto jpianalto is offline
Default 149 tractor vs 782 front blade
Blades are hard to come by around here... What modifications can be done to put a blade from a 782 onto my 149 tractor?
147 w/ 42" deck w/ 3pt hitch all in memory of my grandpa's 124
Old 09-06-2011, 07:42 PM
ksanders ksanders is offline
We put a 1450 blade (same as 149) on a 682 with no modifications except a different lift bar since the 682 lift bar is bigger. You'll have to change the bracket on the blade that the lift bar attaches to and get a different lift bar, but that should be it as far as I know. If that's not it, someone will chime in
Preserving history... one Cub at a time.
Old 09-06-2011, 08:01 PM
I used the blade from my 782 on my 129. Instead of a lift bar, I went to the local hardware store and bought a length of chain to use in place of a rod.
Here is a short vid of me using it: http://s210.photobucket.com/albums/b...t=MOV01814.mp4
Old 09-06-2011, 08:28 PM
Duh!!! Not a 149! A 147!!! Narrow frame. I'm sorry. I teach music and football season makes my brain really dumb to anything but marching band at the moment!!!
What modifications if it can even be done for a narrow frame?
Old 09-06-2011, 09:18 PM
You will need a NF subframe to make it fit.
Old 09-06-2011, 11:01 PM
If I had a sub frame from like a 127 parts tractor? Would that connect okay to the blade?
maddog784's Avatar
That would do the trick.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 09-07-2011, 01:22 PM
I'm just being cautious but I wouldn't think just the little subframe would be the only difference.
Old 09-07-2011, 01:36 PM
A little investigating in our technical libraries can answer a lot of questions...
Old 09-07-2011, 02:05 PM
Thank you!!!
I can't do much investigating at the moment... My house was broken into a month ago and I still don't have a replacement computer yet! . It's only earthly "things" that were taken so I'm okay with it... We now have a security system! But my evening surfing/investigating is very limited on an iPhone... Not to mention it makes my eyes go crazy! Lol. Thanks a bunch! I hope to be up and running in no time. :$
AR James.
