Old 09-06-2011, 07:50 PM
lukeott lukeott is offline
Default Curtis cab??????
I picked up a curtis cab that was on a IH 285 1978. I'm thinking that it should with some mod. and repair should fit on a 1450. I would like to give pics but don't know how. Trying to find what model it is with no luck. I can tell you that the windshield is pretty large with electric motor wiper, which only has the motor piece on the outside, so I will need an arm and blade. It has 2 head lights with wire guards mounted on the side up front near top. It also has 2 holes on top which I thinking is for running lights, there near the front. Also a set of lights near rear side in back guessing more running lights. All the plactic is like new, was stored in a rubbermaid like container. Real heavy weight stuff. I think that will probably need mod work too. Rereading I should have said the electric motor for wiper is there too. There are 2 tears in the roof sheet metal where again I'm guessing someone back up into something, easy fix. There also at one time was a head liner in it, you can see where it was glued. That a lot so I'll stop there. Luke
