Old 09-06-2011, 08:35 PM
jbollis's Avatar
jbollis jbollis is offline
Default Floor Board Tread Plates
Are the floor board plates/ traction pads ,interchangeable between the 82's and say the Quite lines? I guess the easy question is will the steel tread plates for a Quite line or other model fit the 82's correctly ?
I need to put something on my newly painted fenders and cant find anything. I don't really want the replacement rubber kind.
Any help, or suggestions ?
Thanks Joe
Sold everything but one.
Old 09-06-2011, 08:49 PM
I would stick to the rubber ones,On the metal ones it is just another place for rust to form...
Old 09-06-2011, 08:52 PM
jbollis's Avatar
I was thinking Aluminum, but everybody lists them as fitting the quite lines or wide frames.
Old 09-06-2011, 09:02 PM
Well I know a set from a 1x6 1x7 will line up with the holes,but you will have one extra hole,and without a fastner in it,it will prolly rattle.You would also have to make a cut out on the right side for the rockshaft.
Old 09-06-2011, 09:09 PM
jbollis's Avatar
I guess I will just have to pick up a piece of diamond plate and make my own.
Old 09-06-2011, 09:31 PM
They are not a different size, but you can use them on a 82 series by drilling one extra hole for the back bolt. Did that on my 682...
They don't trap stuff and cause rust any worse than the rubber ones.
Old 09-06-2011, 09:40 PM
Matt,
You know when I laid them on the 782 they look a whole lot better than the rubber ones.Some would not drill extra holes,"wanna keep it correct",but I see nothing wrong in doing it for this purpose.
Old 09-06-2011, 09:48 PM
Exactly. I had them and I used them. They weren't doing me any good sitting in a box.
I was going to make some out of aluminum diamond plate, but that may be asking for dis-similar metal corrosion where they contact the fender pan. The salt in the winter will also destroy them.
Old 09-07-2011, 07:42 AM
jbollis's Avatar
Thanks guys, I might see if there is a cheep set on ebay.
Old 09-07-2011, 08:41 AM
juniors1282's Avatar
I bet Mike has a set or two he's not gonna use!! You might want to check with him. He's right down the street from ya.
1966 IH cub cadet 102x2
