Old 09-10-2011, 02:24 PM
CaptMax's Avatar
CaptMax CaptMax is offline
Default HELP: Tiller box and Sleeve hitch?
I've mounted my tiller box and was mounting my Brinly sleeve hitch when I ran into troubles. Now before I go do something stupid and cut or grind, what's the secret to getting my Brinly hitch to fit correctly? My hitch bracket is hitting the tiller box here as seen in the picture. I have tried the lower mounting holes and the upper holes, still hitting the bracket. Is there something I am overlooking? Or do I need to make some owner modifications? Any help is appreciated!!!
CaptMax
Here is where it hits:
I know it has been done before, like this one.
Old 09-10-2011, 02:34 PM
Max you can put some extensions on your sleeve hitch or buy a sleeve hitch that will clear the gear box. I've been Lucky and have two that will clear the gear box.
Heres a link with pics of the extensions.
http://www.onlycubcadets.net/forum/s...ead.php?t=8474
Old 09-10-2011, 02:50 PM
CaptMax's Avatar
Thanks Duke!
I had no idea there was such a thing as extensions for a sleeve hitch. Now why didn't I think of that? It sure is nice to have a forum like this where all your Cub questions get answered so quickly, you guys are the greatest!!
Now does anyone here have a set of those extensions they want to sell?
CaptMax
Old 09-10-2011, 04:09 PM
Originally Posted by CaptMax View Post
Thanks Duke!
CaptMax
Max you can make those your self.
Old 09-10-2011, 04:26 PM
I think you will also have to have an extended lift pin when using the hitch, and the standard pin for lifting the tiller.
Old 09-10-2011, 06:21 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
I know http://www.xtrememotorworks.com has an extension kit for $68 (kinda pricey).
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 09-10-2011, 08:18 PM
CaptMax's Avatar
Well I got it!!
I almost forgot about the custom stainless steel hitch I bought from a member here on the forum. It fit like a charm!!! Thanks again guys, here are some fresh pictures for you to see. I also wondered if there was any easier way to fill my rear end back up with Hytran that I lost while mounting the gear box? That plug in the rear is really buried behind the gear box!!!
CaptMax
Old 09-10-2011, 08:24 PM
You get to take the gear box off to top it off.. But to make things easy on myself, I have a really big syringe with a couple feet of hose I use to inject hydro fluid into the rear. A big turkey baster would probably work as well too.
Old 09-10-2011, 08:30 PM
CaptMax's Avatar
Thanks DX3, I did use a syringe and hose last time. I kinda figured I could unbolt the gear box and just swing it out of the way a bit. Thanks again for all the help!
CaptMax
Old 09-10-2011, 09:08 PM
cub123's Avatar
cub123 cub123 is offline
Thats a sweet hitch ya got there,that thing is heavy!
