Old 08-08-2009, 12:44 PM
1811 1811 is offline
Default IH model 2 Tiller
I had purchased a model 2 tiller. It was on an 1811. The person I had bought it from, lived 3 hours away and brought it up to his cousins for me to pick up about 30 min away. I am having trouble mounting this on my 1811 with 3pt hitch. From what I was told, it was mounted on a 3 pt hitch without the arms, just using the bracket. What I'm finding out is that I can't get the gearbox mounting frame to mount on. It has a special handle on it that has a place for a pin at the top but I can't seem to figure it out any suggestions would be very appreciated.
Old 08-08-2009, 01:17 PM
Merk Merk is offline
Can you post some pictures?
Old 08-08-2009, 01:58 PM
here are some pics of what I have. They are all attachments b/c I doon't know how to just put pics straight onto the thread.
Old 08-08-2009, 03:18 PM
You're missing a piece that bolts onto the 3-point where the drawbar normally bolts onto.
Old 08-08-2009, 06:33 PM
what do you mean by drawbar. My thinking of a drawbar is that part that mounts onto the 3 pt arms to allow you to bolt a sleeve hitch adapter to.
Do you have a link or picture I could see Matt G.
I would still keep the big black 3 pt plate on the tractor though right?
Old 08-08-2009, 07:44 PM
aagitch's Avatar
aagitch aagitch is offline
Matt means the piece that hooks to the back where you would hook a lawn cart to. Right now your draw bar isn't on which is good, but he's saying there should be another piece (for the tiller gbox) that connects where the draw bar would normally connect to
Old 08-08-2009, 09:32 PM
I don't think I have a picture...
Old 08-08-2009, 10:01 PM
ok gotcha, I just thought it was called a hitch or hitch plate. Thanks.
Old 08-09-2009, 03:05 PM
I think I might have found a picture of what you mean Matt G. There would be a plate that bolts onto the 3 pt and the gear box would just slide on and get pinned in the top where the top link would normally go? There are to little fins at the bottom of the handle bracket on the back of the gear box and my guess is they would just ride on that plate in the grooves on the back of it? And the bottom of the gear box mounting frame would be pull against the plate by the tension of the belt?
part #1
Old 08-09-2009, 06:09 PM
I have no idea what that picture's from, but that's definitely not it. I'll have to look and see if I have a picture.
