Old 09-21-2011, 08:33 PM
roaf3 roaf3 is offline
Default What to change on Clutch of 124
HELLO ALL,
I am preparing to take the engine out of the 124 to gain access to a full clutch replacement.
I am trying to make the clutch and the brakes work like they are supposed to .
What items should I replace to make this thing as close to new as possible.
Is the OEM stuff ok or do I need a new rig?
My son who is 8 will be helping to plow this winter so I am trying to make this right for him.
Many Thanks,
Roy
Old 09-22-2011, 10:28 AM
Originally Posted by roaf3 View Post
HELLO ALL,
Many Thanks,
Roy
Roy unless you are going to be using your 124 as a puller the stock disk will be fine. Check the condition of your teaser spring, throw out bearing, and the 3 pin driver and bushing. Depending on condition the return spring might need to be replaced.
http://www.partstree.com/parts/?lc=c...&dn=0019000008
My soon to be 8 yr old loves to get seat time on his 125! This is a great hobby for the whole family!
Old 09-22-2011, 10:34 AM
scleve scleve is offline
What problems are you having? clutch , brake or both?
Old 09-22-2011, 10:38 AM
Donny Curtis's Avatar
Donny Curtis Donny Curtis is offline
Default clutch
Duke is right, that is all you need, if you son is only 8, he would never be able to push in the clutch on Millers set up.
Donny
Old 09-22-2011, 05:15 PM
The clutch is rattling terribly.
The teaser looks broken and the clutch is going to the floor almost before engaging..
The adjustment knob is out as far as it can go.
If my son is going to drive it I need it safe and back to factory.
Cheers,
Roy
Old 09-22-2011, 06:32 PM
Roy, it's not to bad of a fix when you get the engine out, makes life alot easier. If it were me, I'de replace everything except the disc's if there in good condition, ie not rusted or groved, and if they are, you can take them to a machine shop and have them turned, as I did.
Replace it all that you have it apart, and look at the service manual for adjustments.
Old 09-22-2011, 06:41 PM
Excellent advice..
