Old 09-21-2011, 09:58 PM
tukn20s tukn20s is offline
Default Sleeve hitch measurement
Can any provide a center to center measurement for the area marked in red?
Old 09-22-2011, 12:11 AM
LarryW's Avatar
LarryW LarryW is offline
I measured mine in the dark but looks like 4". Mine is for a narrow frame though. Not sure if they're different?
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 09-22-2011, 10:30 PM
Thank you.
Does anyone know if this measurement would be the same for a narrow and a wide frame. Mine is a wide frame.
Old 09-22-2011, 11:01 PM
LarryW's Avatar
I would guess they are the same but thats guessing.
Are you making your own? Maybe put a few different holes in it for different travel/power arrangements? Put one at 6" and you could move the world, lol.
Cub Cadet 1811
Old 09-23-2011, 12:09 AM
bocephus1991's Avatar
Default Hitch measurements
Here are some hitch measurements for you.
Brian
Old 09-24-2011, 03:12 PM
No not trying to make my own, just trying to get the one I have to work. I picked one up from the guy I bought my tiller from. It is a homemade unit, but he had made quite a few of them and even had them on his other cubs and they worked fine. It didn't come with all the pieces so I have been picking them here and there. Anyways, everything fits on the tractor but the lift bar hits the axle/rearend before the hitch is all the way down. It looks like I can just move mounting hole up but I wanted to make sure that was the issue before cutting/drilling. The lift bar is a reproduction as well that I purchased from ihccw.com (i believe). The measurement on mine is 5" so based on the information provided, that seems to be the problem.
