Old 09-23-2011, 11:03 AM
cubcadet100's Avatar
cubcadet100 cubcadet100 is offline
Default Engine question
I have a k241 with a broken rod, if i got it bored and got a new rod could it be made into a 12 horse. I was thinking since i had to get a rod and get it bored anyway why not up the horsepower i also planned on getting a pulling cam for it so does that mean i would have to get one for a 12 horse
Original, 100 with fenders creeper lights 3pt spring asst., 147 with electric lift IH hubcaps, 102, 126, 682 QA36 snow blower, 2 Dozer blades, Haban sickle bar, John Deere 60 Lawn tractor with deck and snow plow, 1962 Fordson super major backhoe, 1941 Allis Chalmers WC
Old 09-23-2011, 08:40 PM
westofb's Avatar
westofb westofb is offline
My advice would be to ask a reputable machine shop about it. The problem doing this is the way the blocks are cast, the bottom of the cylinder on a 301 & 321 (not sure in the 241, but suspect it is the same) is very thin, it kind of provides downward toward the crank and gets very thin walled. Boring it to the next size might make it weak and ultimately destroy the block. A good machinist can look at it and advise you on whether or not that this is doable or not.
Jeff
Brookfield, MO
________________
Old 09-23-2011, 09:08 PM
If the PTO end of the block has "K301" cast into it, you can bore it to the K301 standard bore. If not, don't.
