Old 09-28-2011, 03:05 PM
1811Cub 1811Cub is offline
Default Will a 1810 engine fit in a 1811 with no issues ?
I decided to try to acquire another cub so I can use 1 for parts and another to use. 1811's are hard to come by so Im trying to determine what other models would be most compatible with my 1811
Eric
Old 09-28-2011, 03:31 PM
mrcubcadet's Avatar
An 1810 has the same motor as an 1811 (M18)......so yes, the motor -and most other parts- would work on an 1811, also.
An 1810 is the exact same tractor as the 1811, except for having manual lift.
Oh, and .....
-105___ Tiller
Old 09-28-2011, 04:06 PM
Oh, and .....
Same info goes for the 1812 as well.
I'm sure someone will know what all tractors had the M18 and expand your search for tractors.
Old 09-28-2011, 05:36 PM
esarvey's Avatar
esarvey esarvey is offline
Default m-18 engine Kohler
The m-18 is used in SGT's 18__, Cyclops, 1541,1862, cira 1995 appox. then they switched to command series. so any 82 series can handel m-18.
DaDuke of
2145,1864,1811,1810,1541,1330,1210,1020,1641,147,1 24,73, IH FARMALL CUB. 7254, 1863, IH 982
Old 09-29-2011, 08:03 AM
Leadslingingdaddy's Avatar
http://washingtondc.craigslist.org/n...601713273.html
A start....
Old 09-29-2011, 11:57 PM
CCSuperMan's Avatar
This a horizontal ????
Old 09-30-2011, 06:48 AM
No, it isn't, but the cylinders, rods, pistons, heads, carb, air filter, mag, and a few other odds'n'ends are the same.
