Old 10-01-2011, 02:31 PM
Wayne Wayne is offline
Default Giant neutral-Cub 108
Thats how my problem is best described. Suddenly neutral is huge, and I can barely find reverse, 1 and 2 out at the far edges. 3 cant be found at all. It seems something like this happened just a few years ago but I've lost all memory about it except that it was hard to fix, but not as bad as I thought it would be. Whats going on and how do I fix it?
Old 10-01-2011, 03:22 PM
Jmsoucie's Avatar
Jmsoucie Jmsoucie is offline
sounds like some sort of shifting fork problem take out the 8 bolts on top of the trans around the shifter pull that off and see whats going on inside there.
1966 122 /snow plow blade
3- original cub cadets
2- 100's
3- 149's
5- cub cadet pulling tractors
1650, 70, 71, spirit of 76, 123, 102, 147, 800, 1641.
Attachments- brinly pp 1200 moldboard plow, snow blower, 3- snow plow blades, brinly cultivator, home made soil finisher, driveway grader.
Old 10-02-2011, 08:03 AM
Monzaman78's Avatar
Monzaman78 Monzaman78 is offline
Check in the Techincal Library-Tractor section under shifter repair. Have the same problem on my 104. Great info and pics by Merk.
If You Aint Gettin Dirt In Your Beer You Aint Racin
Old 10-02-2011, 10:32 AM
Repair links:
http://www.onlycubcadets.net/forum/s...ead.php?t=4624
http://www.onlycubcadets.net/forum/s...ead.php?t=4625
http://www.onlycubcadets.net/forum/s...ead.php?t=4626
Old 10-02-2011, 10:14 PM
Oh boy. This looks like.. a... job..... for......... THE PROCRASTINATOR.
Old 10-03-2011, 07:19 AM
scleve scleve is offline
LOL! Good one!!!
O _____ O 27670 O 38245 O 49448 100 _____
All W/Fenders, 3 Point, Lights, Brinly Adapter
124 ______ 106 ______ 107 _______ 127 _______
All W/Hydro, 3 Point, Lights, Brinly Adapter
108 _______ W/Factory Electric Lift, 42" Blade, Brinly Adapter
109 _______ W/Factory Electric Lift, 1A Tiller Both/Ext
2 10" plows, Dbl Disk Harrow, Spring Tth Harrow, 2 42" Tool Bars, Box Blade, Yard Sweeper, Aerator 3 Sets Wh wts., Dethatcher, Garden Cart, York Rake(in pieces), Ect...
Old 10-23-2011, 10:17 PM
Ok, I can only wait so long or the snow might win.
Do I have to remove the transmission on a 108 to do this job, like Merk said he did for his 70, or can I just split the frame to gain access to the 8 bolts I need to get off?
Old 10-23-2011, 10:27 PM
Take the fender/seat pan off of the frame. That gives you complete access to the top of the transmission.
Will look like this when removed:
Old 10-23-2011, 10:28 PM
You would just have to remove the fender pan to access the shifter.Just as DX3 described.beat me to it.heheheh
Up to 534 and counting...
Old 10-23-2011, 11:27 PM
Heck, if I'd known that I wouldn't have waited so long. Well, yes I would. Ok, I will start. Tomorrow I will remove a few bolts.
