Old 08-12-2009, 08:11 PM
Default 16 HP in a 1250?
I recently picked up a 149 which came with a bad motor, but the deal included a 16 hp magnum...It has a fuel pump, and a ignition switch setup that will also need to go, and was mounted to a huge leaf blower thing.. It has the wide base, not the cub style base..
I set it into my 1250 chassis and it looks like I should be able to mount it solidly, not Iso mount it.. If I want to iso mount it I will have to adapt the stock 1250 pan to it, and it looks as if that will reduce oil capacity a BUNCH...
So.. other than the transmission of all that awful vibration to the chassis am I nuts to think of doing this?? I have seen the same motor solidly mounted in the Economy/power King, and other machines...
Tractor is destined for use as a loader tractor and utility use..not going to use it to mow with, as the loader pump will probably go right where the PTO clutch would have been.
Flame away! :biggrin2.gif:
Old 08-12-2009, 09:35 PM
A loader doesn't need very much power. Putting a 16 in front of that is kind of a waste, in my opinion. Pulling stuff around doesn't take much power, either. You'll run out of traction LONG before you run out of power. I'd save the 16 for something requiring more power.
Old 08-12-2009, 10:41 PM
RChristensen RChristensen is offline
Inactive Member
There are different configurations of 16 hp Mags. Some can be modifed to fit the Quietline oil pan with some work. Others take a major modification. I have one that I have looked at over the years to install in a Quietline but it looks like more trouble than it is worth.
If you mount it using the wide base directly to the frame the drive shaft will probably be at a angle that will require a different type of universal joint.
