Old 10-01-2011, 08:59 PM
Rob M Rob M is offline
Default 1872 Axle Seals
I have a bad leak on one of my axle seals. While I'am doing this what else should I be replacing while it is apart?
Old 10-05-2011, 05:33 PM
j.m.jackson j.m.jackson is offline
Rob,
Is anything else leaking? If not.... there's really nothing inside to break or replace, as long as all the mounting bolts are TIGHT. I hope you don't find what I did, broken mounting ears and bolts broken off in the housing.
Also, make sure your frame tunnel cover is on with all 4 bolts, and that they are TIGHT.
--Mike J.
Taylors, SC
1872 - running and mowing!
1882 - in progress
1772 - in pieces, Farmall 200 with a fasthitch 2 point sickle mower, Farmall Super A with cultivators, hillers, middle buster
JD 330 w/3 point, Scag SR-18B on mowing duty
Old 10-05-2011, 05:51 PM
You might as well replace both sides while you have it apart. Otherwise the other one will start leaking next week and you'll have to do it all over again.
Old 10-05-2011, 07:11 PM
Are you changing the Hytran fluid if needed and hydro filter also?
