Old 10-03-2011, 08:54 PM
LarryW's Avatar
LarryW LarryW is offline
Default Will wide frame attachments fit my 1872?
I am wondering if wide frame attachments will fit my 1872. I was thinking they would but someone told me they wont. I understand lift rods or what ever might not work but as far as attaching? I found a johnny bucket Jr for a wide frame and also looking at a push blade for WF is why I am asking.
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 10-03-2011, 09:45 PM
Not really...aside from the mower decks and the 2-stage snowblowers, the super attachments are super-specific.
Old 10-03-2011, 09:56 PM
LarryW's Avatar
Hey Matt,
Is the frame wider on a super? Or is the bolts or QA latch in a different spot? I can fabricate, maybe you would know if it would be easy to make a Johnny bucket JR mount the front?
Thanks
Cub Cadet 1811
Old 10-04-2011, 08:03 AM
No, the front frame interface is identical, but the longer frame makes a WF blade not work, and the tractor sits much higher because of the front axle and larger tires.
The Johnny bucket will physically fit the frame, but it might hit the tires and/or not reach the ground. The front tires on a super are further forward than on a GT because of the design of the axle, as well.
Old 10-04-2011, 08:29 PM
LarryW's Avatar
Thanks Matt, Exactly what I was looking for!
Cub Cadet 1811
Old 05-20-2015, 10:38 AM
shaqdaddy86 shaqdaddy86 is offline
I swapped a super axle on my 149- do you see any issues with running a super mowing deck on the 149 then? Besides the belt size (assume I could weld a narrower pulley on the deck drive spindle?) Thanks! Derek
