Old 10-06-2011, 04:46 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
Default 782D lean
We have noticed that whenever our 782D is sitting on concrete the whole tractor leans to where the left side is a little lower than the right. It doesn't affect it mowing except when you are mowing on the side of a hill. The tires are the same size too.
Anyone have any ideas why it does this?
Old 10-06-2011, 06:28 PM
Are the tires on each side inflated the same?
You could also have a bent frame (unlikely) or broken/missing frame-to-trans bolts, or a broken transaxle case (more likely).
Old 10-06-2011, 07:30 PM
Vince_o Vince_o is offline
Bent frame, didnt notice mine till I took the fender pan off.
Old 10-08-2011, 04:14 PM
chevy13045 chevy13045 is offline
My 1572 lean was the result of a crack in the frame starting by the rear engine bolt hole and going up to where the frame spreads and the typical broken rearend mounting ear and someone's attempt to drill another hole further back. I say attempt because not only was the hole not in line with the original but was drilled crooked. NICE!
