Old 10-06-2011, 10:08 PM
Default 1872 spews Hy-Tran! Help!!
I am a long time OCC lurker and an even longer time Cub Cadet owner (first one was a used 86 with a brand new K321 upgrade I got in 1980).
So my current issue. I have an 1872 that I have had for 15 years. The problem has only occurred 3 times (that I know of) during my ownership.
All of a sudden the Hy-Tran oil will spew from near the steering box. It happened today. After a cold start-up, I drove the 1872 out of the shed (30 feet) at 1/4 throttle, 3/4 hydro control engagement (no attachments on except the three point hitch) and the oil was a continuous stream on the floor!!
I shut the tractor off, waited 3 minutes, restarted and had NO oil coming out.
I used the tractor for 2 hours (very light hitch work) and the 1872 leaked no more oil.
So my question is; Does the steering box have a relief valve that vents out of the hydraulic system or where else could the oil come from?
P.S. Previously this happened with the mower deck on and the Hy-Tran lubed the deck belt so well the blades stopped in 6" grass!!
Old 10-06-2011, 11:18 PM
cub1450's Avatar
cub1450 cub1450 is offline
I don`t know what would cause that I`ve heard of them blowing seals out and countiously leaking but not to start and stop.
hopefully somone will chime in that knows these things.
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
