Old 10-08-2011, 09:58 PM
guido guido is offline
Default QA-42A top link dimensions?
Only one more item that needs attending to on this new to me QA-36A snow thrower. The operators manual gives two desciptions for this piece..."top link and lift strap". At any rate, the ones on this unit were fabricated by the previous owner and appear to be too long.
Are the dimensions the same as the holes on the lift bracket?
Can anyone supply the distance (on center) of the two holes in the top link?
Regards, Guido
Old 10-09-2011, 08:20 AM
Maybe this will help....
Old 10-09-2011, 08:53 AM
Thx Roland,
I do have the break down and the operators manual. They do not give dimensions though.
I may have to remove the deck and mount it to the 127 and see how the wear edge rests on the pavement.
Should the wear edge rest flat or raked forward?
Regards, Guido
Old 10-09-2011, 04:30 PM
I mounted the blower and it does appear to canting forward a bit. The links I have measure 12" on center.
I think 11 3/8" looks more like what it needs.
Your thoughts?
Guido
BTW: quick attach my foot... it won't come off.
Old 10-09-2011, 07:08 PM
Donovan M.'s Avatar
i agree with the quick attach crap. it took me two hours to put mine on.
Donovan:
62' Original-fenders
Old 10-09-2011, 07:32 PM
Do this and you can roll the tractor in and out of it...it takes longer to put the belt on than put the attachment on the tractor.
Old 10-09-2011, 08:51 PM
Donovan M.'s Avatar
i put mine on my 126 but now its on 124
Donovan:
Old 10-09-2011, 11:00 PM
Donovan: Getting it on was a breeze. Much easier than the dozer blade. Removing it was another story. The pins were stuck that slip into the QA assy. I wound up removing them to get it loose.
Matt: The top links that came with this unit do not have the provision to use the link as a jack. This is one of the reasons I am looking for the dimensions.
Dimensions please... Bueller, Bueller
Guido
