Old 10-09-2011, 11:56 PM
ihnick's Avatar
ihnick ihnick is offline
Default NF hydro lift/ plow hook up?
How do you guys hook your brinly hitches up to your Narrow frames with hydro lifts? What holes on the bottom brackets do you put the hitch on and what holes on the lift straps do you put the pin in. I can get the plow to dig good but not lift high enough or to lift high but not dig good. I can't find an in between
Nick.
Old 10-10-2011, 07:54 AM
mmzullo mmzullo is offline
I made a longer lift pin for the 3 point. About 1.5 longer.
Old 10-10-2011, 08:33 AM
ihnick's Avatar
Ok I can do that in machine shop at school. With the longer pins, what holes do you use
Nick.
Old 10-10-2011, 12:45 PM
I use the top holes in the lower bracket. It has more lifting capabilities with the longer lift pin. Just have to adjust the lift straps to get the good lift and depth. I have no problems with this position. I think it's on the 2nd from bottom hole for the lift straps.
