Old 10-11-2011, 09:01 PM
travis.robben's Avatar
travis.robben travis.robben is offline
Default weekend arrangements
I'm trying to convince some of my Buddys to go plow this weekend so I can try out my duals I just put on my 129. My stack in the pic is bent back because my brace broke a while back
ihcadet
Old 10-11-2011, 09:57 PM
You'd be better off without the duals for plowing. The furrow side actually needs to fit in the furrow, and since you have wide tires to begin with, the land side one probably won't even touch the ground.
Old 10-12-2011, 08:15 AM
Default duels
yes i know it dont look like the duels would touch the ground and they dont but now i got to cut the spacer down and that should do it
ihcadet
Old 10-12-2011, 04:08 PM
It will not matter with tires that wide...the land side one isn't going to touch the ground, and you cannot have a dual on the furrow side.
Old 10-12-2011, 04:24 PM
Merk Merk is offline
by Matt G.
I agree with Matt and I plow with a narrow width tire(s). My 8.50 wide tire barely touches the ground.
Dual wide tires is a breakage waitng to happen.....there is less weight (pound per square inch) per each tire touching the ground. Wide tires are for staying on top of the ground-not digging in.
Are those 26-10.50-12 tires?
Old 10-12-2011, 09:55 PM
Default duels
yea i cut down my duel spacer today and it put my tires a lot closer togeither and tryed plowing with it and it worked better then befor and i only got duel on the one side but with wait attached it seemed to help me a little more i think the tire is 26 -12 -12 but not for sur cant remember have to look some time and as far as the duels go if they dont work ill just take them of and just use them for discing and i dont have duels on the furrow side
ihcadet
