Old 10-13-2011, 01:55 PM
jmroy's Avatar
jmroy jmroy is offline
Default Twin Cylinder Engines
Ok, so based off of my post in the wanted section I know even less about the twin cylinder Kohlers than I thought. From what I understand from Matt the crank cases are aluminum but the cylinder jugs are cast iron on the Magnum and KT series? Did Kohler ever make a fully cast iron twin cylinder?
The whole reason I'm looking for one is to build a twin cylinder puller. The class I'm trying to get into has to be originally 16-20hp, and maintain the stock stroke, so I won't be going crazy I'd just rather start with the best base possible and go from there. How would the newer aluminum v twins hold up to being beefed up to push like 30 hp? I'm thinking that might be a better route since they have the advantage of over head valves.
Web Developer - Need a website? Contact me.
Old 10-13-2011, 05:25 PM
Maybe the K532 and K582 are totally CI, but I don't know for sure.
Due to the large number of performance parts for the Kohler Command V-twin engines, I would say you could be successful with one of those.
Old 10-13-2011, 08:14 PM
The pullers are taking the v-twins and putting out as much as 100HP from what I have heard, so 30 would be a walk in the park!
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
