Old 10-13-2011, 02:57 PM
Abeach6882 Abeach6882 is offline
Default Disassembling the 106
ive come to a halt im not sure if the piece where the creeper controls come up through the frame is part of the frame itself or if that piece comes off some how. it seems to be stuck in the exact same place on both sides but im not seeing any bolts holding it to the actual frame. can somebody help?
Thanks.
Old 10-13-2011, 03:23 PM
jmroy's Avatar
jmroy jmroy is offline
That piece doesn't come off, its spot welded to the frame. If I'm reading this right you're talking about the tunnel cover right?
Web Developer - Need a website? Contact me.
Old 10-13-2011, 03:28 PM
Pics would help a ton!
Old 10-13-2011, 03:38 PM
yes jmroy. thanks for the help.
Methos: Im working on pictures here soon i just havent uploaded them to my computer from my phone yet. i will soon though.
Old 10-13-2011, 03:39 PM
This might help some, not sure:
http://www.ccmanuals.info/pdf/Danco%...%20Install.pdf
Old 10-13-2011, 04:02 PM
Ahhhh if you are talking about this part of the frame it is indeed part of the frame and does not come off. A negative of the narrow frame.
Old 10-13-2011, 07:18 PM
thanks guys i appreciate all of your help. Im glad i joined this forum. everybody has been of great help so far. thanks again everybody.
Old 10-13-2011, 07:27 PM
I'm glad we've been able to help you!
Old 10-13-2011, 07:36 PM
the pto handle that is on the left side of the tractor has a rod that passes through the pedastal( where the battery box is attached) to engage your pto. my pedastal is missing the bracket to mount the clutch lever(#10) in the link. http://www.partstree.com/parts/?lc=c...&dn=0011600009
Is that rod held on by a set screw or just a pin. the rod being # 9 and where it attaches to #25 http://www.partstree.com/parts/?lc=c...&dn=0011600015
Old 10-13-2011, 07:53 PM
I should have a extra bracket if you want it. Part is free but the shipping isn't. A cotter pin holds it in place.
I'm not sure about #9 and #25.
