I picked up a 125 from the original owner and it came with this center grader blade. Does anyone have any info on it? I can't even see how to mount it. Any help would be greatThanks Rod |
this is a simplisity allis chambler bladed, likly a/c because its yellow and not orange, i have the same one but orange, im gonna mod it to fit my 72
Matt might be able to suggest something....he has a centre mount blade on one of his tractors.
Looks like a back blade. Think it hooks up between the two rear wheels? Dont think that makes sence. Cant see the pins on the frame hooking up any where under the front axel. Looks like you would need to flip around the blade if mount is between rear wheels. I bet you can make it work..........
I bet you could put those pins at the front into a bare mule drive and use that to attach it to the front. Then, all you have to do is come up with a way to connect it to the lift and you're all set.
Now that is a attachment I would like to have. Would be nice for my gravel driveway. Anyone ever make one?
Jeff
782 w/Honda power 129 stock for now... 100 basketcase |
I have a cutting edge off of a grader blade from work and am going to make something similar. It is off of a 12 foot moldboard and the edges are rounded off and need trimmed to square things up. Might try around 60 inches wide. You can always shorten it up if it's too much. I don't I plan on rigging it to the deck lift. I have dual hydraulics on one tractor and might try using another cylinder for tilting the blade. Haven't decided how complex I want to make it yet though.
129 , Two 149's , 1450 , 10'' moldboard , single gang disc , Two 1A tillers with extensions , 42'' and 54'' plow blades , and half of a 128!!:biggrin2.gif: |
