Old 10-18-2011, 08:09 PM
krhoover krhoover is offline
Default using a garden plow
Is there a method for using a Brinly Garden plow? Do you just put it on the ground and go? I want to use one on my 1450 to start a drainage ditch to put 4" pvc drain pipe into and want to go as deep as I can with the plow before getting out the shovel.
Old 10-18-2011, 08:14 PM
Here is the operator's manual. It will tell you how to set up the plow and use it.
http://www.onlycubcadets.net/forum/s...ead.php?t=4692
