Old 10-20-2011, 11:34 AM
all4jpn all4jpn is offline
Default new guy here
Hey All....i havent picked it up yet, but a friend of mine is giving me a 1650 that has been sitting for 2 years. Said it had an oil leak, and might need a coil. Supposedly it has wheel weights and chains. I recently finished my CJ2A and wanted a smaller project. I thought about a Farmall Cub, but as my wife pointed out,it might be much for 1/3 of an acre in suburbia Since i told my buddy to ask around, he mentioned his 1650. Plans are to get it running and use it for snow duty (have a plow blade I got from another friend), then come spring, tear down and repaint.
What are the common things I should look for(ie engine oil pan wear from worn isolators) and service.
Pics to follow next week when I go and dig her out
Old 10-20-2011, 11:37 AM
Old 10-20-2011, 12:21 PM
Welcome to OCC. You will like the 1650. A BIG single cylinder Kohler with tons of power. Will do anything you want it to do.
Obviously more than likely you will need to replace the ISO mounts. While you have the engine out for that, do the cradle mod and replace the gaskets and seals to stop the oil leakage. It would also be a good time while you have the oil pan off to see if it still has the two balance gears inside. If they are it is highly suggested that you take them out. They do have a tendency to explode and make a nice window in the side of your block. More so if the motor is original and never been redone. More than likely you will need to remove the driveshaft and replace the flex disks at both ends and also replace the drive shaft bushing in the drive plate on the motor and in the rear shaft connector.
Change all the fluids including the Hydro rear end and the filter with correct HyTran fluid. Will take 2 gallons to refill the rear. Put a new set of points and a condensor on and set the timing per Matt's method located in our Tractor Tech library.
Download and print all the manuals;
Carb Rebuilding: http://mgonitzke.net16.net/tools/carb_rebuild.pdf
ISO mount and snubber: http://www.onlycubcadets.net/forum/showthread.php?t=7
Hydro Filters: http://www.onlycubcadets.net/forum/showthread.php?t=12
Ignition Circuit: http://www.onlycubcadets.net/forum/showthread.php?t=27
Ignition Coil: http://www.onlycubcadets.net/forum/showthread.php?t=11
Spark Plug Chart: Use Autolite: http://www.onlycubcadets.net/forum/s...ead.php?t=4638
Static Timing for new points: http://mgonitzke.net16.net/tools/static_timing.pdf
Chassis Service Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4644
Kohler Service Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4646
1650 Operators Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4670
PTO adjustment: http://www.onlycubcadets.net/forum/showthread.php?t=30
Wiring Diagrams: http://www.onlycubcadets.net/forum/showthread.php?t=22
Cradle Mod: http://www.onlycubcadets.net/forum/s...ead.php?t=4630
This should keep you busy for awhile till you get your 1650. Read up on everything and you will be ready to go.
Old 10-20-2011, 12:39 PM
Congrats and looking forward to your pics!
Old 10-20-2011, 12:42 PM
DWayne that's the mother load of helpful links! I am a little shocked that you didn't link any painting and restoring links to your list tho.
Old 10-20-2011, 12:47 PM
Default hey
awesome..exactly what I was looking for
Old 10-20-2011, 12:48 PM
LOL, my hand was getting tired, and I needed to leave you something to do,,
Old 10-20-2011, 12:50 PM
Glad to have you!
Old 10-20-2011, 01:28 PM
Rest up and try again my Jedi in training!
Old 10-20-2011, 01:38 PM
Someone's into Star Wars.
