Old 10-24-2011, 12:56 PM
Bugjunkie66's Avatar
Bugjunkie66 Bugjunkie66 is offline
Default Hitch Style
I just got a 149 to replace my old 1959 DB Suburban as the garden workhorse. By DB has a cat 0 3 pt hitch and I wonder if I should go with the same style on the 149 or go to a sleeve style for Brinly attachments?
Old 10-24-2011, 01:04 PM
CHWNY's Avatar
CHWNY CHWNY is offline
I would keep the 3pt and add an adapter for the sleeve pin. Someone here has photos of an adapter w/ 2"receiver and sleeve hitch.
Old 10-24-2011, 03:27 PM
If you already have Cat. 0 implements then I would say put on a Cat. 0 3 point. If not, Sleeve hitch implements are much cheaper and easier to come by.
www.xtrememotorworks.com is the only site I have seen that has a Cat. 0 lift designed to fit the Cub WF's.
Old 10-24-2011, 04:15 PM
The Sears 3-point is not a Cat-0, it is their own 3-point hitch. The Sears stuff is probably worth something to someone who is into that, so I'd sell those implements and get sleeve hitch implements for your 149.
