Old 10-25-2011, 09:32 AM
Dundee Dundee is offline
Default 147 - Fuel Petcock issues
I have a new to me 147. The fuel shut off petcock (above the bowl) is giving me problems. When I screw it in and shut off the fuel, fuel drips through the threads of the petcock. When I open it up to use the tractor, the screw is loose and vibrates partially closed. Is there a fix, or do I need a new one?
Thanks.
Old 10-25-2011, 09:51 AM
I have had these need new packing behind the nut, if I am remembering the 147 correctly.
If there is a nut around the screw, try tightening it, then on to repacking.
Or I'm sure you can get a plastic replacement.
Old 10-25-2011, 10:05 AM
Thanks for the reply.
Sounds like a picture may help. Here it is.
What do you repack it with?
Old 10-25-2011, 03:22 PM
IROCKWITHDIRT's Avatar
IROCKWITHDIRT IROCKWITHDIRT is offline
Had the same issue on my 147 recently. There's a cork washer in there. Tightened the packing nut on mine to near rounding it out and the seeping quit. From my research, a replacement needle set thru cub cadet would cost bout what a complete aftermarket sediment bowl setup costs. Seeing how mine is missing the screen and the bowl gasket is old dry cork too I may go that route.
Wore out 129. Projects: 1969? 147, 1971 chevelle SS conv 402/4sp bench, 1965 chevelle wagon, 1973 trans am drag car, 1973 triumph 650 chopper, and oh yeah, working on the house too!
Old 10-25-2011, 03:41 PM
Go to an ACE hardware or other hardware with a knowledgeable staff. Ask for valve packing. It looks like black string (it did "back then").
Wrap some around the stem, replace the nut, leak is gone.
Old 10-25-2011, 04:11 PM
You can get a new rubber bowl gasket through Kohler for a couple bucks.
Old 10-26-2011, 11:12 AM
OK. Thanks, I will do that.
Old 10-26-2011, 01:28 PM
Get a new fuel valve Assy. KH-A-210480, and a gasket KH-210468 and screen KH-210479, don't mess around trying to tape it, it will give you fits in time.
Old 10-26-2011, 07:00 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Tractor Supply
If you have one of these nearby, they have the gaskets too.
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
