Old 10-29-2011, 05:52 PM
Default Diesel Glow Plug Upgrade Indicator Light
A couple of weeks ago I did a thread on my big red smoker having problems with hard starting. After checking the solenoid for the glow plug upgrade I found it to be bad. There was some discussion of a way to make an indicator to show that power was or was not getting to the glow plugs. A fellow member here at OCC offered to make me an LED indicator to see how well it would work.
I got the LED in the mail today already setup to install. All I had to do was decide where I was going to put it and how. I decided to just leave it under the hood and not mess with the dash. If you are wondering why not in the dash, I rarely start the BRS sitting on it. I will just reach over and fire it up in the shop and let it warm up before I move it outside. I have to let it back itself down the ramps as I think the weight of it and me on it would probably make the 2X10 boards decide to break, LOL. So as I engage the key I can just lift the lid a bit and see if the light is on. With that being said, I fabricated a bracket and mounted it on the left side of the battery using a bolt that is used to mount the fuel pump.
I ran a wire to the plug side of the solenoid and the other wire directly up to the negative side of the battery. Now when I turn the key to the left to engage the glow plugs I have a very nice bright blue LED telling me my glow plugs are getting voltage. Also before someone tells me about the wire breaking from vibes, I do plan on getting some electrical connectors and shrink wrap to improve the connections.
Yes it would be considered a PO mod if someone else buys it, but I hope it is one that is considered worth doing...
Thanks to CHWNY (Clay) for fixing and sending the LED.
Here are some pics of the setup.
The bracket I made in about 5 minutes:
The LED installed into the bracket:
Wire hooked up to the Glow Plug side of the solenoid:
Second wire hooked up to the Battery Ground:
Light showing blue when the Key is engaged to heat glow plugs:
Old 10-29-2011, 06:05 PM
CHWNY's Avatar
CHWNY CHWNY is offline
Hey it does work!
Clay
Old 10-29-2011, 06:10 PM
It sure does.
Old 10-29-2011, 08:17 PM
Nice job Dwayne!
Old 10-29-2011, 08:24 PM
Nice job Dwayne!
Thanks. It's the simple things that give me great pleasure... LOL
Old 10-29-2011, 09:43 PM
LarryW's Avatar
LarryW LarryW is offline
Thats cool guys! Great idea!
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 10-29-2011, 11:19 PM
Excellent work, buddy!
Old 10-30-2011, 11:57 AM
Clay great job on hooking DWayne up! DWayne good job on the install!
Old 10-30-2011, 01:26 PM
CHWNY's Avatar
These days If I can make someone SMILE even just for a moment, Life is Good!!
Clay
Old 10-30-2011, 02:29 PM
emptypockets95's Avatar
emptypockets95 emptypockets95 is offline
Great job! I am going to that to mine!
Justin
