Hi all,I have a question , how do you remove the pulleys from the spindles on a 44A deck? are they pressed on,is it a tapered spindle saw they are keyed. I've about drove myself crazy trying to get it off . Like to never got the nylock nut off it! Any help would be greatly appreciated! thanks ,Brian
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
Once the nut is off, up they come. Not easy, I bent one to pieces getting it off to put another one on using pry bars. Most people say to remove the blade and take out the retaining bolts for the spindle and then drive the spindle down out the bottom of the deck thru the pulley. Spray it real good with PB Blaster too.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Thanks Dwayne,will give it another go tomorrow. The pulley is rusted pretty bad ,bearing feel like their in good shape yet. Doesn't wanna give up without a fight ,been on there 32 years!....lol
PB works great, I like croil but $$$, you could warm up the pulley w/ mapp gas. If your going to replace the pulley, heat it good. Don't heat the spindle to much you want the pulley to expand more, and repeat. Be patient, like you said it has a home there, I didn't want to move either!!
Clay |
Well I got one off,supported the bearing flange between two 4x4 blocks and used a 10lb sledge on it and after about 5 wacks it popped off! Now for the middle one. The reason I am doing this is had to cut one stinking bolt off with the grinder,wasn't enough left to use a socket on. The first pulley was rusted away. I should have taken the bolt off the pulley before I removed the spindle assembly from the deck,may have to bolt the two remaining back up and put the blade on and try to wedge it to break it loose. I have been using kroil thats my preferred penetrating oil,not cheap but like it better than pb blaster.Hope to get some done tomorrow evening,broke my cheap-o vise trying to loosen the nut on to top the middle pulley tonight.Thanks for all your help guys!
