Old 11-02-2011, 07:45 PM
LarryW's Avatar
LarryW LarryW is offline
Default Implement and Charge pump spring and cone questions.
I have a ported pump that has never had the hydraulic add on installed. I have been looking at the manual for the 169 hydraulic add on setup here, page 9. http://ccmanuals.info/pdf/169%20Hydr...On%20Setup.pdf So I take the implement spring out(1/32" wire), put in a new thicker spring(1/16" wire) and take the 1/32" I took out of the implement and put it in the charge relief port with a cone. So my questions are,
1- Does the spring pressure here decide the proper hydraulic pressure going to implements and charge pump?
And for me to do this I need a cone and a thicker 1/16" wire spring.
2- Can I use the cone out of another pumps implement relief and put it in my charge pump relief or are the cones different?
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
