Old 11-02-2011, 10:32 PM
greasemonkey greasemonkey is offline
Default need some help with a 122........
I've been going over my Cub 122, and noticed the void of a voltage regulator...... is it supposed to have one? It should be on the grill behind the lights right? It starts and runs fine, but I haven't had the chance to actually test the voltage when running.....
Is this ok? or should I find a V/R asap????
Old 11-02-2011, 10:47 PM
LarryW's Avatar
LarryW LarryW is offline
Its ok as long as you keep your battery on a trickle charger. It wont hurt anything unless the wires that go to it touch something maybe. It just wont charge. I am about 99.999999% sure the v/r is under the hood on the 122.
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 11-03-2011, 05:58 AM
YUYP....it had a V/R...
Old 11-03-2011, 06:38 AM
jbrewer's Avatar
jbrewer jbrewer is offline
S/B there on the front grill frame at the top.
The lack of a VR will be quite hard on batteries!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 11-03-2011, 07:20 AM
so i cant really tell from the picture, but is there a bracket behind the regulator that holds it to the grill?
Old 11-03-2011, 07:40 AM
jbrewer's Avatar
Default No bracket
on my 123 there's just two threaded holes on raised bosses in the grill frame.
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 11-03-2011, 08:29 AM
A picture is worth a 1000 words or...cubs?
Up to 534 and counting...
Old 11-03-2011, 09:13 AM
yep that sounds right.......... mine has those raised bosses...... just making sure it didnt need a bracket.....
Old 11-03-2011, 01:08 PM
I have had a 122 for 5 or 6 years that has no charging on it. I just put a float charger on at night and it will run all day. I have had it at a tractor show all weekend and never run out of juice.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 11-03-2011, 10:31 PM
LarryW's Avatar
I also havent had a charging system on my 147 in years. I need to find a good S/G because I know mine is bad. I think its from a bad VR so I need both. The battery actually last a long time. I dont use the lights at all. Just for starting and coil. I put the charger on it every few weeks or so. When Im using it alot maybe once a week. It has never even acted like it was dying. So you could probably do it less often but it is hard on lawnmower batter to deep cycle it.
Cub Cadet 1811
