Old 08-21-2009, 11:50 PM
papaglide's Avatar
Default rear seal on my 127
Alright guys here is where I'm at: I admit I am not a mechanic sooooooo I started the process to change my right axle oil seal. I got the cover off, the clip that holds the axle in place is off, and well I am stuck with what to do next. The brake would be my guess and then the axle should slide out and thusly the seal can be replaced? What do I do next? Here is a pic: Great thing is that NO SLUDGE whatsoever was found in the backend!!
Old 08-22-2009, 12:14 AM
Looking good papaglide.
Clean rearend. Must have been well taken care of
Old 08-22-2009, 03:11 AM
Mike in NC's Avatar
Mike in NC Mike in NC is offline
Remove brake, then slid axle out. Remember to lube the new seal when you put the axle back in.
Mike Murphy Mike & Jen's Old Engines Original OCC Member #23
Cub Cadets: 102, 128(X2), Model 1 tiller, Model 1A Sweeper, QA-42A Snow blower, 38" CI end mower deck, QA 42" mower deck, Brinly cultivator, Brinly 10" plow, sleeve hitch adaptor
Old 08-22-2009, 12:36 PM
papaglide's Avatar
Thanks Mike. Lube with the hytran, correct?
Old 08-22-2009, 07:04 PM
papaglide's Avatar
Do I take the caliper off the disc or take the whole brake assembly off of the rear axle housing?
Old 08-22-2009, 10:12 PM
RChristensen RChristensen is offline
Inactive Member
Papaglide Some people use a pan to catch the hydro fluid when they remove the back cover.
:biggrin2.gif:
Old 08-22-2009, 11:48 PM
papaglide's Avatar
Funny...the crap on the floor is from the rear axle housing. After I took the rear cover off and DRAINED IT INTO A PAN, I busted the rear axle housing loose and a whole crap load of hytran came out and snuck its way onto the floor!!
Like I asked earlier, "Do I take the caliper off the disc or take the whole brake assembly off of the rear axle housing?"
Old 08-23-2009, 11:57 AM
papaglide's Avatar
Well, my plans are on hold until Monday. My local dealers are closed so I don't have the parts.
Old 08-24-2009, 11:19 PM
Mike in NC's Avatar
I just took the caliper off and left the bracket on the axle tube. I put some trans fluid on the seal and some on the axle where the seal will touch the axle. Put a drain pan under the trans case to catch any fluid that comes out after draining. If I were you, I would replace both seals while you have it apart. (maybe you had that planed.) Sorry for the delay.
Old 08-25-2009, 08:20 AM
papaglide's Avatar
Good Morning!! Thanks Mike. I never even thought about changing the other one but that makes sense! I ordered the gasket and seal yesterday and they should be in Thursday. I will update then. Thanks again for the help!
