I picked up this 123, it would run but only with throttle in certain positions. Had a rear axle shaft leak, and when brake pushed down, the hydro is just barley
engaged. Fixed oil seal, took carb off, cleaned and kit. Adjusted brake and hydro. Now I have no spark. Have power to positive side of coil but nothing after, spark plug will not spark, nor points. I wired safety wires together, still nothing? Has to b a bad wire is all I can figure. I have changed plugs, wires, coils, condenser, points, nothing. I'm sure it's minor, just driving me nuts!
To much to list! |
Here is a simplified Kohler Ignition Circuit Diagram..... Ignition Circuit
Do you have a good ground connection...??
Everything checks out good, but no spark. Pulled everything of of a running 123, it will not spark on this 1, put parts back on the other, it runs !!!! Starting to get annoying! Been messing with it off n on for about 3 weeks now, has to be a wire, is all I can figure
To much to list! |
Had a similar problem and found out it was the point wire was touching the cover on the inside. Just a thought.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
try a new coil and condencer. i did that on my 124 and it ran like no tomrrow.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10:
