Old 11-08-2011, 07:27 PM
Donovan M.'s Avatar
Default 1450
I'm in the process of buying a 1450. Is there any thing special I should know about them? Any secrets I should know?
Donovan:
62' Original-fenders
Old 11-08-2011, 07:50 PM
You are looking at a Quiet Line series, the series known for ISO mounts that usually are bad if they are original. Not a big issue, but the motor has to be removed to fix them, and if they are bad, more than likely the Drive line, "drive shaft, bushings and flex discs will need replaced too. If the motor can be moved around by hand side to side the ISO's are shot. More than likely you will have to repair the trunion on the hydro, not a bad thing if you can weld or have a buddy than can. With these minor issues fixed, they are great tractors just like the others. Also there is a mod called a cradle mod. Do it while the motor is out, it will reduce the ISO deterioration problem.
Here is a list of links you will need to visit and download.
Quiet Line Links:
Download and print all the manuals;
Carb Rebuilding: http://mgonitzke.net16.net/tools/carb_rebuild.pdf
ISO mount and snubber: http://www.onlycubcadets.net/forum/showthread.php?t=7
Hydro Filters: http://www.onlycubcadets.net/forum/showthread.php?t=12
Ignition Circuit: http://www.onlycubcadets.net/forum/showthread.php?t=27
Ignition Coil: http://www.onlycubcadets.net/forum/showthread.php?t=11
Spark Plug Chart: Use Autolite: http://www.onlycubcadets.net/forum/s...ead.php?t=4638
Static Timing for new points: http://mgonitzke.net16.net/tools/static_timing.pdf
Chassis Service Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4644
Kohler Service Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4646
1650 Operators Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4670
PTO adjustment: http://www.onlycubcadets.net/forum/showthread.php?t=30
Wiring Diagrams: http://www.onlycubcadets.net/forum/showthread.php?t=22
Cradle Mod: http://www.onlycubcadets.net/forum/s...ead.php?t=4630
Old 11-08-2011, 09:01 PM
CC1650Dave's Avatar
Not to be a wise guy, but your signature line shows you own a 1250...
So you know the in's and out's of the series. Take your 1250 and put a 14hp in it, add a hydraulic lift to replace your manual one, and you've got a 1450.
Old 11-09-2011, 08:35 PM
Donovan M.'s Avatar
im getting a 1450 from our hiredhand on our farm. he ows me $75 for an engine i sold me. so he said he will buy me the tractor.
Donovan:
