Old 11-16-2011, 09:16 PM
Chris08527 Chris08527 is offline
Default Home Service
Hey guys,
My local certified Cub Cadet repair shop does not come to the house??? and I can't get it to the shop . . .
Anyone know how I can find certified Cub Cadet tech in central NJ, that makes house calls???
Old 11-16-2011, 09:40 PM
I think there was one in Florida, but, he died!!
Google it!!
Old 11-17-2011, 05:10 AM
Vince_o Vince_o is offline
You mean they dont offer a pick up and delivery service? I thought everyone did that. We only do it 1 day a week now in the off season but in the summer the truck runs 5 days a week 8 to 10 hrs a day.
Any MTD service center can do warenty work on it for you. Call around, or better yet call MTD and they will get you someone that will pick it up and pull it to the shop for ya.
Now whats it NOT doing?
Old 11-17-2011, 10:55 PM
Vince it runs like a champ, i would just like to have it serviced to keep it that way!!!
Old 11-18-2011, 06:16 AM
Chris
I totaly understand. Best to keep it that way. Id call around to some more mower shops and see what they will do for ya. I dont know what mower you have, but if its a belt drive unit it can go anywhere. Heck Im working on a "Toro" at the shop now, that is nothing more than a troy bilt bronco with a differant hood on it. The spindels for it are around 105 and going threw our mtd suplier they are 75. If I was toro I would be ashamed to have put my name on that!
Belt drive are all about the same. Check your drive belt for cracks, if you have a small trans belt and a veratior, chek the trans belt. Loosen the drive belt off the 2 or 3 idles under the frame, you most times can roll the belt off the idlers, and check for noise in them. Ife replaced them with as little as 15 hrs on a mower. Check your deck pull the deck belt off and spin your spindels, listen for the berrings to see if they have noise. Also look at the shafts, be sure they are turning straight. If youve never hit anything, you sould be fine. Then sharpen the blades.
On the eng, you wanna chage the oil, 50 hrs, or once a year. I prefer once a year for the home owners. If you have a kohler courage, you want to look for oil leaks at the valve cover and on the sump under the flywheel schroud. Change a plug, whats 3 bucks these days, look at it make sure it was burning good. And I always check the air filter a few times a year. Thats just as important as checking the oil!
Some prices, we get about 120 bucks to change a drive belt, that includes the belt. On the ones with the veratior, a little more cause it has 2 drive belts.
Deck belt and sharpen we get about .75 in labor plus the cost of the belt. While the deck is off I sharpen the blades, grease the spindels if they are greasable, clean the deck, and check all the idles on the deck, reinstal and check the level.
Just an oil change and grease, is like 30 bucks. Thats 2 qts of oil and a filter, grease the wheels axle, ad deck.
We do a compleate service with pick up and del for 190. Then if you need more work, drive belt most times, theres a huge savings to the cust on the labor rate.
Hope this helps, Vince
