Old 11-18-2011, 09:48 PM
Johnson_John1982's Avatar
Johnson_John1982 Johnson_John1982 is offline
Default Struck Mini Dozer
Does anyone on here have any experience with one of these machines? They look pretty effective on some of the videos I have seen and cost less than a skid steer. Seem like it would be pretty handy around the farm. Anyone wanna put in their two cents?
File Type: jpg stuck-magnatrac-mini-dozer_260788879320.jpg (38.1 KB, 179 views)
Old 11-18-2011, 10:04 PM
I have one, the psi on the tracks is so low, you need cleats on the tracks to do anything.
Mine has never had cleats, but, I never tried to make it "work".
I got a 1872 shortly after getting the Struck, the 1872 made the Struck a "Shop Ornament" .
Old 11-18-2011, 10:27 PM
I appreciate the advice. I have some rental property and thought it would be good for moving dirt and gravel around in the yards and also for moving around gravel inside of block before we pour the slabs. Weve been using a small Deere with a blade on the front but it doesnt turn very tight and tends to sink in loose gravel. I was thinking a small piece of machinery such as this would be handy for those types of situations.
The initial cost of a skid steer is way too much for the little bit of use that I would get out of it but renting one for an extended period of time can be pretty costly as well. Im kind of in a pickle.
Old 11-18-2011, 11:27 PM
That's a neat dozer.
Old 11-19-2011, 10:13 AM
Makes me wonder if it'll fit on my trailer!
Old 11-19-2011, 10:43 AM
Only if the "1200" gets off the trailer at the same time the Struck gets loaded!!
Old 11-19-2011, 12:09 PM
Umm you've got me a thinking!
Old 12-12-2011, 07:19 PM
Eye candy for Duke!!
Old 12-12-2011, 07:50 PM
Thanks for giving me something to dream about tonight! Hows your run? I just told Allen that I bet that is hard on the driveway and garage floor. Sure does get my interest up tho!
What ya got for info? Any links you can share?
Yes you've got me thinking !
Old 12-12-2011, 08:06 PM
It currently has a tired 5hp flat head Briggs IC engine. This winter it will have a new 7hp Briggs electric start.
Drive is belt, manual lift blade and it has a sleeve hitch (OOOHHH!! That will get you dreaming!!)!
I think that is a Gravely 2 wheeler blade. I think that from what the Gravely guys say about 2 wheeler blades having more curve and can roll snow better.
The flat tracks go right over concrete!! No damage. Reasonable traction in dirt, really needs "cleats".
