Old 11-20-2011, 07:16 PM
scott H's Avatar
scott H scott H is offline
Default snow/dirt blade lift arm
Any one seen this type of lift arm on a blade? I've looked at tons of pictures and haven't run across one that looks like this. I'm making my own plow mount since I can't find one without a blade for less that a c note. Is it for a "float" type blade?
Scott
Old 11-20-2011, 07:19 PM
mmzullo mmzullo is offline
I think that"s for an 82 series tractor. I have 1 just like it.
Old 11-20-2011, 07:22 PM
scott H's Avatar
Default 82
Ok, so since I'm making my own mount it should work on my narrow frame?
Scott
Old 11-20-2011, 08:59 PM
CHWNY's Avatar
CHWNY CHWNY is offline
It is for 82 series. I just picked up a 42" from a 682. I think the slot is for when you push dirt it won't bend the lift rod.
Clay
Old 11-20-2011, 09:02 PM
That's not an 82 series bracket. It looks similar, but someone made that one.
Old 11-20-2011, 09:14 PM
CHWNY's Avatar
Default Bracket
Here's mine WAY DIFFERENT
Clay
Old 11-20-2011, 09:32 PM
Mine just has a hole, no slot.
Duke isn't the only one to get a "Monday" IH decal!!
I would think the slot would be nice on a hydraulic lift.
What would be the advantage of a slot on a manual lift??
Old 11-20-2011, 09:40 PM
Attachment 17580
Haha someone was backwards that day!
Old 11-22-2011, 08:23 AM
It all depends on how you look at it. From the front seat or in front of the tractor! There is supposed to be 2 holes to lock the lift arm with a flat plate. I'm not sure if mine has it or not but have seen them with the locking plate. Also it's a 5/8 rod not a 1/2 rod.
Old 11-22-2011, 09:14 AM
CHWNY's Avatar
So this one is stock?
The two holes are for a lock plate?
What is the purpose of the slot?
Clay
