Hey Guys,
I’ve got some 1440 troubles! I went down to the building to get the ol’ girl out for one of her last flogs around the yard before winter sets in and the battery was dead… No big deal, I’ll just charge it up! But before I got in too far I found that the negative lead and it was loose, so with a few quick twists of a wrench I was back in business! She fired right up! I pulled the hydro lever back, something felt weird and the tractor was barely moving. I looked thru the opening in the dash to see that the lever was riveted on in 2 places and the bottom rivet was broken, which resulted in the lever having a lot of slop! I figured this was the culprit to the slow/no movement issue, and that it shouldn’t be too difficult to repair, so I decided to fix it… 5 hours later I was buttoning everything up from my lever repair and I proceeded to fire her back up to see if my handy work paid off… She was reluctant to start and would only do so for a short period of time (maybe 5 seconds), with the choke on, then it would die (Is the fuel varnished? Did the carb get some trash in it? The low fuel light wasn’t on, but I’ll fill her up just to make sure before I try again). It was getting dark, so I flipped the ignition switch over for the lights to come on so I would at least be illuminated while I was cussing, not just shouting bad words all over the place in the dark, and now the electrics are dead! The lights just flipped on for a second and now there is NOTHING from the switch at all, so I assumed the battery was in-fact stone-dead now, so back out it comes and onto the charger. Can’t you tell my Saturday and Sunday were pleasant, fun-filled days of joy? As of today the battery is back in, fully charged, but still nothing. What is the problem? I’ve checked the only fuse I know to check (20-amp off the solenoid), but it looks fine. I know everything went back together as it should have because the tractor fired after my “repairs”. If I need to remove the carb for a cleaning I don’t mind to do it, as the new gas is subject to varnish without use for an extended period of time, but I wanted to get her back into the building before I get into that job! Which brings me to the next “opportunity” - the hydro release doesn’t seem to be engaging, so the heavy hussy won’t move! I pretty much dragged her down the ramp to my building onto flat ground and the rear wheels were rotating in opposite directions, but I don’t think it hurt anything due to the soft ground, and the short distance. To simplify this post I’ve listed my troubles below, and thanks to those of you who choose to offer assistance! Happy Thanksgiving! 1. NOTHING from the switch – no lights, no starter, etc. Where should I look? 2. Tractor is now only running for just a few seconds then it dies. Is this a fuel delivery issue? I’ll make sure it has plenty of gas before going too deep… 3. Hydro release doesn’t seem to be engaging. Any tips on getting it to free-wheel so I’ll at least be able to roll “Big Bertha” up the ramp, and back into her bed? Thanks again in advance for the help! |
First- I have edited out a couple of your words that goes against one of our forum rules that I am sure you have read over and understand but in case you haven't here is the link.
Rules link: http://www.onlycubcadets.net/forum/s...ead.php?t=4592 Rule: By agreeing to these rules, you warrant that you will not post any material that is obscene, vulgar, sexually orientated, hateful, threatening, containing bad language, swear words, pornographic or otherwise violative of any laws. The Forum is considered a G rated or Family orientated site and posts should reflect same We do have family members such as wives and children that read posts and will keep our site family safe. Second- I am sure you will get some great advice to your issue. A little patience should yield some great comments for you. We have a great amount of knowledge here that love to help. I hope you are able to get it up and going soon.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Wiring Diagram sent to the E-Mail address list in your profile.
Best thing to do, and probly did, was start with the test light. Follow the power, sounds like you did. If your not getting power, FROM, the switch, is there power coming TO the switch? Im not real good at wiring, but I try to read it like a road map.
Relay problems, SOMETIMES, will give the problems your describing. Also you do have 12v on the batt,yes, how about under a load? If it drops down below 11, your batt is shot. Its real important that the batt is good, not just 12 v showing on the VM. I had tried to up load a batt test to do in a PDF file, but its too big for this forum. Or you can buy this one with 60 hrs on it, but it aint cheap! LOL |
Hey Guys,
Just an update - I haven't gotten to the 1440 yet... I know, I know, poor excuse for a Cub owner! Anyway I wanted to thank those of you who offered help and I think I'll start with the "power-chasing" method Vince suggested. I wonder if the switch is bad since there is absoultely NOTHING when the key is turned? I did yank the battery and have it load tested - turned out to be just fine. I've had the battery on a Battery Tender since, so I don't think I'll have any issues with it. Does anyone have any suggestions as to why the hydro won't unlock? Is there a secret to it? I've pulled the lever and nothing seems to change... Dang tractor is pretty heavy too, so it won't be fun pushing/pulling it to the garage... |
Check your fuses first
I did one the other day, troy broke, and the fuse was melted. At first I didnt take it out, just probed on the top, tested good. BUT When I hooked up the switch, no power on the switch. Just enough resistance no to light up the test light when plugged in. Pulled the fuse and it was melted and I guess just enough was still togeather to light the light on both sides. |
Take the time to look at all the connections. The plugs on the wiring harness on the 2182 I just picked up are rotted so it's time for me to do a re-wire job. Way too many ignition switches get changed when the problem is someplace else.
