Old 08-27-2009, 05:56 PM
Cub124 Cub124 is offline
Default Sloppy Steering
The steering on my 124 is very sloppy. i can push the steering wheel forward,left, and right. Is there somthing i can tighten up or get to fix this? And what is a super steer upgrade and would that fix my problem?
Old 08-27-2009, 06:30 PM
RPalmer's Avatar
RPalmer RPalmer is offline
Have you checked the 2 mounting bolts?
Old 08-27-2009, 07:00 PM
67hydro's Avatar
67hydro 67hydro is offline
Take the steering wheel off and put a front wheel bearing in the steering tube,the shaft will slide through the middle and the outside fits perfect in the steering tube.There is originaly a plastic bushing that goes in there!
Jason Davis
Old 08-27-2009, 07:05 PM
Thanks guys i will do that 67hydro. Everything looks to be hooked up right.
Old 08-27-2009, 07:29 PM
Hey guys what is the secret to getting the steering wheel off? I've got the cover and nut off but what do i do next?
Old 08-27-2009, 08:19 PM
redwaycc's Avatar
redwaycc redwaycc is offline
i have yet to remove mine but here is a link that explains how to do it .....http://cubfaq.com/steeringremove.html
100(2) 128, 129, 76(1/2)
Old 08-27-2009, 09:06 PM
gary1930 gary1930 is offline
My method...
I have an eye bolt in the ceiling of garage, with a come-along attached. I mainly use it for removing engines, but it works for steering wheels too.
First, the PB Blaster, and lots of it over a couple days, tapping on the loosened nut as I apply it.
Then I wrap a chain around the base of the steering wheel, attach it to the come-along, and elevate the tractor so that most of the weight is pulling up on the wheel. Whack the loosed nut a few times, and sooner or later it pops loose. I've done three that were on there for 30-40 years this way with no damage to the wheel or threads.
Old 08-27-2009, 09:25 PM
Originally Posted by gary1930 View Post
My method...
That may not damage the wheel, but that's a great way to wreck the steering column casting. Supporting the tractor by the two bolts in the aluminum steering box casting is not good for it at all. A better way is to get a 5/8 NF bolt and nut, thread the nut halfway on, thread the bolt into it, and then pound on the bolt while pulling up on the wheel with your knees.
Old 08-28-2009, 12:07 AM
ajgross ajgross is offline
Inactive Member
I found it even eaisier to do what Matt did but instead of a hammer, I used a air hammer and the thing popped off real quick.
