Old 12-03-2011, 04:22 PM
Tim S. Tim S. is offline
Default Tiller model
What tiller models will fit a 1650, what is the difference between models. Tried looking in tech. library for implements but couldn't find info.
thanks, Tim
Old 12-03-2011, 04:49 PM
Pretty much all of them will fit your 1650. The only differences is that the #2 and #2b were designed for the 82 series tractors which use a 5/8" pulley on the rear pulley drive. If you buy one of these all you will have to do is swap the pulley out for the correct one. Any of our sponsors should be able to help you out with that.
