Old 08-29-2009, 08:07 PM
bayranger's Avatar
bayranger bayranger is offline
Default Hey Yall, From South Carolina
I am new and am very excited about restoring my 149
Old 08-29-2009, 08:25 PM
papaglide's Avatar
welcome to the group!! THIS is the place to get the help you need!!
Old 08-29-2009, 08:50 PM
bayranger's Avatar
Thanks, I have many questions, Just to sum up a little generator not charging,
pto clutch running all the time. the biggest is the drive shaft is welded up in that knuckle that is supposed to have a pin. will a weld work? just got the machine.
Old 08-29-2009, 09:24 PM
RPalmer's Avatar
RPalmer RPalmer is offline
Welcome to the forum.
To check the generator on your 149. Remove the field (yellow) wire from the generator. Start the tractor and touch the removed wire to ground. If you hear it start to pull down it is working and the cause is most likely the voltage regulator.
A pto that always spins most likely has a bad bearing.
I hope this helps.
Old 08-29-2009, 11:05 PM
bayranger! Glad to have you! I'm located in NC.
Old 08-29-2009, 11:39 PM
bayranger:
Welcome to our Forum..........
Old 08-30-2009, 12:14 AM
bayranger,
I have a 149 also, great tractor.
