Old 12-06-2011, 01:22 AM
wig wig is offline
Default QA-36A Snow Thrower rod question
For those of you who have this model or the 42", I need a couple of measurments. I bought mine without the chute control rod (the long rod with handle that turns the chute) and the rod gaurd (the small rod coming up from the side of the thrower that has a small eye-let bent in the end for the chute control rod to go through) I'm looking for the total length of the long rod from the coupling to the handle and the total length of the small rod from end to end. The small rod should pull out from its slot to get a total length or just eyeball it. Also the inside diameter of the eye-let would be great. I have bought the 3/8" rod and a new u-joint and plan to make my own with a improved handle. Will post pictures as soon as completed. Thanks for any help with these measurments.
Red 782 w/dual hydraulics & Ags. Power angle snow blade, QA 36A snow thrower, rear IH blade, tiller, #2 trailer, mower, custom made winter cab and brinly plow.
Old 12-06-2011, 10:01 PM
maddog784's Avatar
Default Here to help
The length of the handle is 32.5 inches from the end of the rod to the front of the handle. As far as the chute angle rod holder, it is 17 - 18 inches long. As the owner of a 782 and a QA-42A, I will tell you that the factory rod holder will touch the sheet metal on your 782. I would recommend making a custom eyelet for your combination - that's what I'm planning to do.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 12-07-2011, 01:21 AM
wig wig is offline
Thanks for the measurments and the heads-up on the rod holder . Can you tell me the size of hole the use for the eye-let on the rod holder. Is it a tight fit or loose?
Old 12-07-2011, 04:42 PM
maddog784's Avatar
It is a loose fit - about 1" ID.
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 12-07-2011, 08:31 PM
Sugarmaker's Avatar
The pictures of the chute control rod are show and posted by bsyprit (sp) in my thread about the restoration of a QA42. Hope that helps. I think I will try to make a custom handle from some 3/8 o.d. stainless tubing.
I will try to take a picture of the rod (holder and the eye dimensions too.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 12-07-2011, 09:04 PM
For an 82 series, the rotator rod holder should look something like this:
Old 12-07-2011, 09:07 PM
Sugarmaker's Avatar
Matt is correct that is a slightly different set up than a narrow frame.
Regards,
Chris
