Old 08-30-2009, 08:35 AM
bayranger's Avatar
bayranger bayranger is offline
Question Drive shaft welded?
Just got the 149 and its pristine. but there is a knuckle that bolts to the motor that pins to the drive shaft that hooks the the hyd. The nuckle must have worn out and the previous owner welded it but a spattered bead and a not so good job. Of course it broke.
I am not sure that there might need some play there and a weld would never hold, or if it did it may wear out the rag joint.
Does anyone know?
BR
Old 08-30-2009, 09:12 AM
Here is what the Parts Manual indicates for your Drive Train...
You could also modify your Drive Train to this...
