Old 12-13-2011, 10:25 PM
thenrie's Avatar
thenrie thenrie is offline
Default Hey, when you guys buy tubes for your rear tires...
What kind of valve stems work best? Some tubes are offered with bent stems, but most are offered with straight stems. Some even have offset stems. Which work best on Cubs with the 23X10.50 12s? Is one better for use with wheel weights? I plan to fill them with washer fluid. Does that make a difference? Are there any makes/models of tubes that work better than others? Any to stay away from?
Tony
Stafford, VA
1650, 682...
Old 12-13-2011, 11:50 PM
cubs-n-bxrs's Avatar
I didn't realize there was that big a selection on tubes. Everyone I have ever purchased has has straight valve stem.
Old 12-13-2011, 11:53 PM
Leon renaud Leon renaud is offline
If you plan on running wheel weights I'd run tubes with long bent stems if you can get them that's what my father in law had on his 123,That might even be what it had new.I put wheel weights on my 104 and now the tubes are a problem to get at luckily the Ags and tubes are both new.
