Old 12-14-2011, 06:50 PM
mtomac mtomac is offline
Default 782 with cast rear & aluminum axle housings
Is it possible this early built CCC 782 came from the factory this way?
Old 12-14-2011, 07:04 PM
Yes, aluminum axle tubes were used with the CI rear since partway through the preceding QL series, and 82 series tractors had CI rearends until serial number 720,000.
Old 12-14-2011, 07:22 PM
So what exactly is the aluminum rear ends that people refer to on the CCC/mtd built garden tractors?
Did any 782's have cast iron axle housings?
Old 12-14-2011, 07:36 PM
tractordude tractordude is offline
The alum fine spline carriers are black, and the back cover looks way diifferent than the I.H. rear ends. as pointed out the fine spline rear ends are the I.H./CCC rear ends. IMHO much stronger also
Old 12-14-2011, 07:54 PM
Serial #720,000 and above have an aluminum transaxle case and axle tubes, and as I was alluding to in my previous post, no 82 series tractor had CI axle tubes.
The aluminum rearends have stronger fine-spline axles and a stronger carrier than the CI rearends do.
Old 12-14-2011, 08:09 PM
Matt G, Did only the 82 series come with the cast rear and the alum axel housings? I find that style rear end harder to find these days, as I have scaled back on cub hunting the past few years
Old 12-14-2011, 08:24 PM
CCC used the CI differentials until they used all of them up that came with the buy out of IH Cub Cadet. Then they built their own out of aluminum. There is nothing wrong about an aluminum case if the machine is used what it was built for and the bolts are kept tight.
Old 12-14-2011, 08:44 PM
That reminds me I need to check the bolts this winter and make sure they are still tight. Would hate to FUBAR that rear due to laziness.
Old 12-14-2011, 08:58 PM
Starting somewhere in the middle of the QL series, aluminum axle tubes were used on a CI transaxle case. This continued through the IH-produced 82 series, and ended with CCC 82 series serial number 719,999. After that, the entire transaxle case was aluminum.
Old 12-14-2011, 09:01 PM
Do you have a 782? If so
