Old 12-14-2011, 10:56 PM
thenrie's Avatar
thenrie thenrie is offline
Default just wondering about tire sizes for the 82 series
Do the 982s come with wider front tires than other models? My 682 appears to have the same size tires as my 1650, front and rear, but pics I see of the 982 seem to have larger or wider tires in front. I like 'em. Will they fit a 682?
Tony
Stafford, VA
1650, 682...
Old 12-14-2011, 11:13 PM
72-149's Avatar
72-149 72-149 is offline
the 982's get 26x12x12 rear & 18x8.50x8 on the front,because they are super garden tractors.they will fit but will be real hard to turn on the front of smaller tractors ,the worm gear is different (gear ratio) & they mite hit your deck because the front axle on the supers is bent forward on the ends if you look at the pics the (1650)yellow is ur axle its strate with no bends in it & if you look at the (982)red one its bent on the ends hope this helps
Old 12-15-2011, 10:16 PM
thenrie's Avatar
Yep. I see what you mean. Guess I'll stick with stock. Thanks.
Tony
Stafford, VA
1650, 682...
