Old 01-03-2012, 06:58 PM
lca10 lca10 is offline
Default 6x4 Extension Contraption
Absolutely sick of getting stuck in the snow I came up with this dooms day machine. Let me know what you guys think. A dumping bed will most likely be in the near future if this does prove worthy.
Old 01-03-2012, 07:22 PM
robpa robpa is offline
tracks is what it needs now.
Old 01-03-2012, 07:29 PM
Sugarmaker's Avatar
I like it, do both rear ends drive? how does it steer? More pictures please.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 01-03-2012, 08:54 PM
I agree I like it impressive engineering at least, maybe a 5th wheel type trailor ! if the front rears high center will it spin and stop ?
128
Old 01-03-2012, 09:00 PM
Sugarmaker's Avatar
It looks like the shifter is still on the second rear end?
Regards,
Chris
Old 01-03-2012, 10:42 PM
That is very cool! I like it, too!
Old 01-04-2012, 12:52 AM
Shaner Shaner is offline
too bad your front drive tractor doesn't have a rear PTO...then you could somehow make a way to connect the shaft on the front of the rear transmission to connect to the PTO on the tractor's transmission. the pto spins the same as the engine, so itd be true four wheel drive with a flick of a lever.
Old 01-04-2012, 08:05 AM
Southtowns27's Avatar
Southtowns27 Southtowns27 is offline
I 2nd the idea for putting tracks on it
Old 01-04-2012, 08:47 AM
Donovan M.'s Avatar
looks good
Donovan:
62' Original-fenders
Old 01-04-2012, 10:53 AM
guido guido is offline
I like the concept. If there is not a provision for the axles to rock over terrain, then tracks would be in order. A split brake would be a good idea too.
Alan
